Case 430 gas engine shot
Pierson farmer
10-23-2006 11:55:30
My 430 motor is on its last legs...had it looked at and all the parts added up to more than the tractor seems worth...was told that trannys are not very dependable(to be honest mine shifted hard). Looking for advice/used motor b/c it was handy...how much is too much to put into it? Thank you
INCase
10-24-2006 06:18:34
 Re: Case 430 gas engine shot in reply to Pierson farmer, 10-23-2006 11:55:30
That's a tough question with any tractor. If you've had the tractor a while you know the history of it. I must say I don't see many of the smaller cases in the junk yards. If I do there's not much left and there's only 1 or 2 (the yards I've been to anyway). Thus I think they're somewhat popular. I believe some Case skid steers, swathers and as mentioned below combines had the 430,530,630 engines in them. New Parts shouldn't be an issue just a matter of part $ labor $ versus tractor value.
Glenn F.
10-23-2006 20:51:02
Is your tractor for sale? Where are you located?
Glenn F.
Nedd
10-23-2006 13:23:04
I've seen good 430's bring $3-4K but $1500-2500 for a nice sound tractor is more reasonable. So if you can buy one at an auction for less than an overhaul it might be worth it. But you might also get someone else's problems. Where are you located? Other Cases had that motor if you can find them. You can also pick up a bigger motor out of old 600/660 combine that would fit into your tractor with a little bit longer hood. Good luck either way.
