LA coolant drain
fredro
10-23-2006 10:55:23
Other than the drain under the radiator, is there a block drain or anything else to drain the coolant? Just want to make sure I get all the water out, and put Anti-freeze in.
Thanks!
Richard G.
10-23-2006 17:08:48
 Re: LA coolant drain in reply to fredro, 10-23-2006 10:55:23
Look between the water pump and the lower water inlet on the block. You will find a small plug which drains the area just below the water pump.
Tom Railsback
10-23-2006 14:45:54
That's the only drain I'm aware of and I've been around them for over 50 years.
