DC foot clutch
glenn b
10-23-2006 10:27:52
Well i finally found my tractor after 20 yrs of lookn. Need insight. Clutch wont disengage,and has minimal free travel.Clutch brake is worn.Must shut off engine to put in gear,when restarted has drag and tractor will move. Ideas before i split it! Glenn
DC Fred
10-24-2006 22:14:32
 Re: DC foot clutch in reply to glenn b, 10-23-2006 10:27:52
Glenn, I had sam problem with DC foot clutch that I bought, prev. owner said he had this problem for a long time. I got it home and adjusted many different ways, nothing helped. Then I talked to a retired case mechanic (freind that I worked with in early 70's), & he told me that foot clutch DC's didn't get enough oil through crankshaft for clutch. He solved the problem by taking inspection cover off & adding 1 qt. eng. oil, PROBLEM SOLVED that was 14 yrs. ago, still going strong & have never split yet.
J Heitkemper
10-24-2006 18:51:07
Are we to assume that you have tried to adjust the clutch ,And have gone thru that trial and error process ,And that You are familar with that technique .. If so .,Then tractor split is in order ,,If not ,hold your horses and just tinker with that clutch adjustment ,No need in going thru unecessary work ,I have seen them so bad out of adjustment that one could experience exactly what you describe ,,if you need more info ,PLEASE do not be afraid to ask ,,Always glad to help ,,Just don't want to annoy you with telling You Stuff you might already know , Good Luck ,Jim
J Heitkemper
10-24-2006 18:49:25
glennb
10-31-2006 16:13:12
 Re: DC foot clutch in reply to J Heitkemper , 10-24-2006 18:49:25
not offended how do i go about adjusting
j heitkemper
10-31-2006 20:51:06
 Re: DC foot clutch in reply to glennb, 10-31-2006 16:13:12
Sorry never have had the need to adjust either DC or SC foot clutchers on this farm, HOWEVER I do believe the principle is the same .I recall on this forum from CamboTed that this is not an over center engaging clutch ,Check those comments O>K, ..... ..adjustment for The hand clutchers :, remove clutch inspection plates ,disengage clutch ,locate dowel pin on the outer part of flywheel ,either by pushing a button in orpulling a post button out ,this may take a little searching,seems to me that some are different over the years built , while depressng pin ,rotate the clutch pressure plate assembly counter clockwise ,til you hear pin reengage the next hole ,,about 2 inches ,,< CASE EXPERTS ,please correct me if I am telling wrong direction> .. I usually test drive to check for right feel ,, and repeat process til satisfied ..locating the pins the 1st time is the hardest part,, keep us posted ,,Good Luck ,JIM
glennb
11-02-2006 14:13:04
 Re: DC foot clutch in reply to j heitkemper , 10-31-2006 20:51:06
tried the oil trick-thats exactly what it is should have known better hopefully can work on it this weekend have feeln it needs to be split
DKase
10-23-2006 20:44:35
Most likely the pressure plate is broke in half. That is what both of mine were. Let us know DK
