Mag. Points
Keevin
10-22-2006 08:53:37
On a DC magnito, the contact on the part of the points that rub on the cam , fell off. I was going to silver soilder it back on but I'm afraid the metal is to thin . Am I close to right or should I go for it? Thanks
Keevin
10-22-2006 13:49:34
 Re: Mag. Points in reply to Keevin, 10-22-2006 08:53:37
It's a Case mag. for a 1948 DC. I can't find a number on it, but it's the little round point where the spark sparks on the thin piece that rubs on the cam that fell off. And a jeweler may be my answer. Thanks
CENTAUR
10-22-2006 13:08:12
The way you described it is the rubbing block that came off.How was it attached? By small rivits or? If it was small rivits I would go to jeweler & see if he or she would have something to fit.It could be tapped or penned.If the points are pitted this would be a good time to correct that by taking each side and very gently touch them on the side of a grinding wheel such as a valve grinding wheel or a reg. 120 grit 6 or 7in.grinder. CENTAUR
CENTAUR
10-22-2006 13:24:43
 Re: Mag. Points in reply to CENTAUR, 10-22-2006 13:08:12
It would be very helpful if you could give Brand&Model so those who know mags could give you a better ans then I tryed to do CENTAUR
