Mounting Rear tires on a DC
Joe C
10-22-2006 05:43:08
I took the rims off the hubs and am taking the rims to get sandblasted and painted. I am planning on mounting the tires on the rims myself. Are there any tricks and tips you guys can offer me to make this more efficient? I do have tire bars, and was told to use plenty of dish soap to slick the tire. Any suggestions are welcome. Thanks in advance.
Glenn FitzGerald
10-22-2006 07:13:05
 Re: Mounting Rear tires on a DC in reply to Joe C, 10-22-2006 05:43:08
Getting them off is the hard part. First, re-mount your rims. Then drop the inside bead of the tire "inside" the top of the rim. Then just work the sides in as you go down. Then put your tube in. Then CAREFULLY (not to pinch the tube)put the outside bead "inside" the top of the rim. The inside bead can usually be done almost completely without tools. The outside will require your tire tools. Being careful not to pinch the tube will be your biggest problem. I mount rear tires with some pretty basic tools: one tire spoon and a couple broken truck leaf springs. New tires,painted rims, dish soap=piece of cake.
Glenn F.
Joe C
10-22-2006 21:03:46
 Re: Mounting Rear tires on a DC in reply to Glenn FitzGerald, 10-22-2006 07:13:05
Actually, getting them off was easy. Since both tires are completely shot, and flat, they came off the rim nicely. To finish the removal I took a sawsall with a 6-inch wood/metal blade and just cut across the tire, splitting it in half. After that, it just fell off. Also, thanks for the information. I hope to put it to good use tomorrow. Wife's Dad comes in Thursday, so I'd better get on it!
