401 Headlamp Question
Doc Larry
10-21-2006 17:28:44
My (1955) 401 diesel has two different sized front sealed beams. I"d like to know which one is correct. Can someone tell me the correct diameter for the front sealed beam (12v?
Thanks, Larry
Vac400
10-22-2006 09:42:11
 Re: 401 Headlamp Question in reply to Doc Larry, 10-21-2006 17:28:44
Doc.
In my parts book they give this number for 12 volt lamp 5943595 seal unit. I hope this will help you out. If you do need the measurements I will be glad to go to the barn and get you what is on my 400 western.
Jerry
Doc Larry
10-22-2006 16:51:54
 Re: 401 Headlamp Question in reply to Vac400, 10-22-2006 09:42:11
Jerry,
If you could just check the lens diameter sometime that would be great. No rush.
Thanks, Larry
