Trying to identify old Case Tractor
Lawrence Parker
10-21-2006 10:22:39
I have a small case tractor 4 cylinder gas engine (40hp class), 2 tone paint (gold/red) with pressed steel wheels. 2 brake pedals on right side, wrap-around 2 piece grill, steering shaft with universal joints down the left outside. On the outside right side there is an oil reservoir. I found the number 137R14671 on the engine block. There are no other identifying marks that I can find. Can someone help identify the model etc. Thanks in advance
Lawrence Parker
10-23-2006 15:24:28
 Tractor identified in reply to Lawrence Parker, 10-21-2006 10:22:39
Thanks for your help. The tractor is a Case 210B-L from 1959.
630crazy
10-23-2006 13:19:16
 Re: Trying to identify old Case Tractor in reply to Lawrence Parker, 10-21-2006 10:22:39
try posting a picture.
John Noname
10-21-2006 12:03:52
From the brief description I would guess it is in the 200-300-400B series. Someone may be able to give you more info on the block number. There isn't a serial tag on the dash? You might go to the tractor photos and search on these numbers. Built 58-60. There also is a 300-400 built in 55-57 but these are the round nose versions.
