DC sparkplug - Which one?
Joe C
10-21-2006 08:20:03
I have a '42 DC dual-fuel. Do I want autolite no.3116 with 18mm threads, or no.3076 with 7/8"-18 threads. What's the difference? How do I tell what I have. Can I cross-reference the old Champion number somewher? Any help is appreciated.
Joe C
10-22-2006 05:07:54
 Re: DC sparkplug - Which one? in reply to Joe C, 10-21-2006 08:20:03
Thank you all!
Walt Davies
10-21-2006 23:13:39
If you have the Multifuel head and like my LA head it has the 7/8 plugs then you will have to use the 7/8 plugs as the 18 mm will fall right though the hole. I have heads for both sizes and there is quite a differance in them.
I use Champion D-21 in my LA with the LP head and they work great. I have tried lower heat ranges with poor results.
I'm not sure of the heat range for the Multifuel engine but any auto parts store can cross referance the ones that you have to any brand.
Walt PS get a hot plug these old engines run cool and need them. Just watch the plug colr when removed Black carboned up need a hotter plug light grey or clean just right brown burnt spots to hot. Covered with white stuff to much resistance.
johndeereman
10-21-2006 16:37:20
why not use the auto lites with a mag i use them in my deere and my dc havent had any trouble?
Glen in TX
10-21-2006 08:52:16
Champion W14, 7/8-18 thread = Autolite 3076
Champion D16, UD16, D18Y, D21, 18mm thread = Autolite 3116 or even a better plug the Denso L14U U groove electrode. Autolite 386 & 388, 18mm are resistor types and don't use those with a magneto.
Joe C
10-21-2006 21:07:36
 Re: DC sparkplug - Which one? in reply to Glen in TX, 10-21-2006 08:52:16
Does a resistor plug with a mag dampen the spark? Would this make the tractor harder to start? I prefer Autolite plugs over Champion.
Glen in TX
10-21-2006 21:41:41
 Re: DC sparkplug - Which one? in reply to Joe C, 10-21-2006 21:07:36
Magnetos were never designed for use with resistor type plugs and carbon type wires and should always use non resistor plugs and metallic core wires with them for longer life out of points, condenser, & coil. You may not notice much difference on a seldom used old tractor mag but on commercial engines with mags it will show in a shorter life out of the mag and manufacturer will not warranty coils if they know resistor plugs and wires were being used. Yes, you'll get a better cleaner hot blue spark with non resistor plugs and metallic wires with a magneto. Resistor type is fine for battery ignition too but that came along to dampen radio interference. Yeah Champions aren't what they use to be and I really like the Denso plugs now and push them over any brand including Autolite.
