case crawler ID What is it?
Janice Jensen
10-20-2006 21:55:26
We purchased a case crawler loader. The guy we got it from thought that it was a 310, but the serial numbers do not match up. It looks like the 310, but also could be a 1000 terratrac. The serial number on the tool box is 7060431. It also has a serial number on the motor,ED206. Not quite sure about the E. The model numbers on the tags are missing. It is a continental motor, 4 cyl diesel, has loader and ripper bar in back. Number on plate in rear has serial #601D 2031.The Terra Loader has Serial # plate 1001321 We would like to get a positive ID so that we can order the correct books. Any information?
Janice Jensen
10-21-2006 19:03:08
 Re: case crawler ID What is it? in reply to Janice Jensen, 10-20-2006 21:55:26
Thanks, George. We went to the Case dealer, and they think it is a 1961,1000, but several things don't really match up. We are looking for a good picture of the 600 Terratrac with front loader, to compare. Hate to order a bunch of books for the wrong model. Our tractor has the one top roller on the track like the 600, but the metal cover on the bottom half of the track(side view) goes the full length of the track. The one picture of the 600 that I saw was different. The gauges are arranged up and down on the dash, and there is what looks like a breather tube on the left side of the dash.
george md
10-21-2006 20:51:25
 Re: case crawler ID What is it? in reply to Janice Jensen, 10-21-2006 19:03:08
Janice,
It sounds like your dealer doesn't know older case crawlers. All 1000 ser # 's start with 710 except the 1000 BR and it starts with 701 . Send me a few pictures of your tractor and I'll see if I can identify it . I have several 1000's and I parted out a 600 . 1000 tractor has cont JD 382
engine. I have the engine out of the 600 diesel. I will send you an email .
george
marv herman
01-21-2007 08:44:28
 Re: case crawler ID What is it? in reply to george md, 10-21-2006 20:51:25
I see you have a 600 terratrac . I would like to find some scarfire blades for mine. Mayby you could help ?
Thanks Marv.
george md
10-20-2006 23:48:54
Janice,
The 706 in the serial # says it is a 600,
the 0431 in the # says it is # 431 off the production
line . The engine model should read ED 208 .
Link below is to the case terratrac group on
yahoo.
george
