case 530 tractor
pete brannan
10-20-2006 14:00:49
would like to know the horsepower of a case 530 diesel tractor and any information on this particular model. thanks.
Tom (Ks)
10-20-2006 17:13:00
 Re: case 530 tractor in reply to pete brannan, 10-20-2006 14:00:49
Stock power is about 42 HP and it can put out 50 pretty easy. Good tractor, 188 CID engine.
R F W
10-22-2006 13:26:56
 Re: case 530 tractor in reply to Tom (Ks), 10-20-2006 17:13:00
My case 430 has the same 188 diesel motor approx 35hp as the 530 --how do I tell what H.P.the tractor is putting out now {has it been modifed} How do I increase the H.P. to 50 plus H.P. Thank you in advance Barney
Tom (Ks)
10-22-2006 14:21:25
 Re: case 530 tractor in reply to R F W, 10-22-2006 13:26:56
The 430 runs wide open at 1750 rpm, the 530 runs at 1900 with a dry clutch, and 2100 with the case o matic. You can run your rpm's up to 1900 to get more power, your injection pump may have a "torque capsule" that points up at a angle, above the round part of the main body that the four fuel lines are attached. If you have one, loosen the jam nut and using a allen wrench, turn the set screw out one or two turns. To know what horsepower it has, you will have to run it on a dyno. Someone may charge $30 to $100 to test it.
