870 3 pt
brdeere
10-19-2006 18:30:18
I have a problem on my 870 tractor. When you pull back the lever to raise up the 3pt and pull it all the way back the tractor acts like it is still trying to pick up the implement even when it is as high as it can go. You can hear the hydraulic pump working when this happens. If you push down a little on the lever it stops? does anyone know the problem?
John Saeli
10-20-2006 04:54:33
 Re: 870 3 pt in reply to brdeere, 10-19-2006 18:30:18
Sounds like the cable control is out of adjustment. Take the cover off the console & adjust the cable from there. It's not impossible to break the whole top cover by not having it adjusted correctly.
turbo
10-19-2006 19:48:34
The A34175 draft cut out lever may be broken or out of adjustment. It is in the upper sensing linkage box behind the 3PT valve.
