Case 580c shuttle jumps from forward to neutral
Mike Victor
10-19-2006 09:05:54
Hi, my 1980 Case 580c shuttle jumps from forward to neutral after driving 50 feet. If I hold the lever in forward position I'm fine. Any ideas on how to fix? Thanks for any help. Mike.
Jim Conley
10-23-2006 05:32:56
 Re: Case 580c shuttle jumps from forward to neutra in reply to Mike Victor , 10-19-2006 09:05:54
On my 580C, on right side of shuttle, there is a plate with 3 1/4" bolts and your neutral safety switch. If you pull that off it has a spring and ball bearing that falls out. Then a detent plate
with 4 partially drilled holes, forward, neutral and reverse are side by side then the fourth is for your neutral safety switch. This is a real pain to get the detent ball, spring and detent plate back. Hope this helps. No fluid lost, and you must remove dipstick tube and adapter.
Mike Victor
10-23-2006 08:36:51
 Re: Case 580c shuttle jumps from forward to neutra in reply to Jim Conley, 10-23-2006 05:32:56
Thanks for your direction, I'll give this a shot.
redranch1
10-20-2006 14:17:24
My lever slipped down so I made a bump out of epozy that the lever goes over and will stay up. Has worked for me for 5 years.
BCnT
10-20-2006 10:04:17
i'm not familar with your tractor but shuttles i've seen use detent balls n springs to hold position...could be a spring broke or gummed up...check your manual for cleaning procedure
