dc running better
kim in indiana
10-19-2006 01:05:03
after draining and filtering the gas and cleaning the tank of my dc . the tractor now runs more than 2 minutes . but it will not accelerate . it only has one speed . if you put it on a load it sounds like the govenor may be working . any help would be great thanks.
Camboted
10-19-2006 06:44:27
 Re: dc running better in reply to kim in indiana, 10-19-2006 01:05:03
Has anyone messed with the linkage between the governor arm and the carburetor? I had a couple of DC's that did that, one had a lengthened rod between the governor and the carb and the other had the wrong carb arm on the butterfly valve. Try disconnecting the governor arm and see if the engine will rev up by moving the butterfly valve manually. LOL!
Mathias NY
10-19-2006 04:29:27
Have you checked to make sure the governor linkages are working?
When I first started my DC, it only had one speed. As it turns out when I painted around the governor, some paint had 'glued' it in place. Once I broke it free and pumped some grease into it, it ran much better.
