vac hyds
tompepper
10-18-2006 19:53:59
Can anyone tell me why my case vac pushes hyd oil out the breather tube when i use the lift.I changed the oil because it had moisture in it and was pushing it out.i figured it was foaming up because of the water,so i draind it and flushed it and now its still pushing some hyd out the breather.I put 6 qt in it.
Joe (Wa)
10-18-2006 20:38:10
 Re: vac hyds in reply to tompepper, 10-18-2006 19:53:59
Does your rock shaft drain tube tee into the breather? If so your piston cup is leaking bye excessively. Torque tube reservoir capacity is 8 qts to the lip of the fill plug opening. It may hold less if there is a lot of grease and gunk built up over the years.
Joe
