Year of Case VAC???
John Sugden
10-18-2006 19:19:18
A friend of mine has a Case VAC didn"t know until I looked and the engine serial number what it was. Went into the picture area and found the tractor, but I can"t find a tag on the tractor. The engine number is VAC12-37361, can anyone tell me what year it is from this? Thanks
Joe (Wa)
10-18-2006 22:31:50
 Re: Year of Case VAC??? in reply to John Sugden, 10-18-2006 19:19:18
For whatever it is worth the breakover from engine serial nrs starting with VAC to A47 occurred during the 1949 model year. If it has a Eagle hitch or a place to bolt the rock shaft, it is an early 1949, if not it is somewhere between 1946 & 1948. The earlier VAB engine serial nr also overlaps VAC 1946 - 1948.
This is just my opinion gleened from the parts manuals and comparing a limited nr of engine serial nrs to the tractor model nrs so the advice is worth just about what you are paying for it.
Disclaimer: if the engine has been swapped out, all bets are off.
Joe
