Thermostat problem
Scott Hawley
10-18-2006 10:04:54
I am having trouble getting my case 580CK to show any temp readings on my gauge. I had replace the old gauge with a new one from the Tractor suppy store and installed a new thermostat which was missing. It worked for about two days, showing about 170 degrees and then it quit..... ..nothing no reading at all. The only thing I changed was to put in a new electonic ignition upgrade in it which screwed up everything, timing, carb settings, but that's another story. It runs fine now once I got the settings back but still no temp reading.
Any ideas would be helpfull.
Thank you,
Scott
Walt Davies
10-18-2006 15:22:39
 Re: Thermostat problem in reply to Scott Hawley, 10-18-2006 10:04:54
That's a pretty easy one you replaced the key switch and it quit then the problem has to be right there somewhere you got a wire in the place. You need to trace the hot wire from the gage to the switch it should be hooked up to the acceries post with the lights.
walt
Scott Hawley
10-19-2006 05:53:55
 Re: Thermostat problem in reply to Walt Davies, 10-18-2006 15:22:39
Thanks Walt for the reply but, I did not mention in the first post that the gauge is not electric. It's the old capliary type so there's no problem with the wiring. I also forgot to mention that I took a look into the radiator right after I started it to see if the water was flowing (incase the thermostat had stuck open) but it was not flowing. The previous owners told me they had done the same thing with a new gauge and thermostat and it also worked for a few days and quit. So they just gave up and let it run the way it is, I would rather find out what's going on and fix it for good.
Thanks again
Scott
Walt Davies
10-19-2006 18:00:42
 Re: Thermostat problem in reply to Scott Hawley, 10-19-2006 05:53:55
Scott, If what you tell me is correct then the only problem would that the water level is below the sending unit at the end of the tube or the gauge is just bad. try testing the water temp with your wife oven turkey temp. Don't let her know about though.
Walt
Scott Hawley
10-24-2006 16:27:14
 Re: Thermostat problem in reply to Walt Davies, 10-19-2006 18:00:42
Thanks Walt, I was afraid I might have to take it out again.I hope it's not the gauge but you never know until you try. Hopefully the water level is the problem instead.
I'll post my results when I find out.
PS. I won't tell my wife about her thermometer either. You have to use the right tool for the job!!!!!
Thanks again,
Scott
