Case 700 brakes
john460
10-17-2006 20:25:40
We replaced the brake pads, springs, and steel balls on a 1959 Case 700. Now, when you depress the brake pedal the brakes will lock and you will have to drop the tractor into reverse to unlock the brakes. Just lightly touching the brake pedals will cause the rear wheels to stop (lock)abruptly. We replaced a similar style brakes on a 1967 Case 730 and 1959 Farmall 460 and had no problems. We checked everything to make sure it was assembled correctly. The brake pads were aftermarket (foreign made) purchased from Case-IH dealer. Anybody have any ideas? Thanks.
C. Amick
10-18-2006 09:22:26
 Re: Case 700 brakes in reply to john460, 10-17-2006 20:25:40
I assume that this is a ramp-ball type braking system. It sounds as if the balls are coming too far out of their ramps. This is normally a sign that the brake lining is getting too thin. In your case, however, could the replacement balls have been smaller or the replacement lining too thin? I think you have too much space in there somewhere.
