Case 970 brakes
john460
10-17-2006 20:00:05
We have lost the hydraulic pressure for the right brake on a 1973 Case 970. There is no resistance when you depress the brake pedal. The left brake seems to be working fine. We tried bleeding the right brake, but this did not help. Does anybody have an answer for this problem?
case trader
10-19-2006 04:06:54
 Re: Case 970 brakes in reply to john460, 10-17-2006 20:00:05
970 used 2 styles one the resavoir is supplied by the hyd. system one you add fluid look under acces cover cover at top of hood if there is 2 caps at master cyl. chk. fluid if no cap you have the late style no checking i had problems w/my foot plunger at master cyl. had to take off master cyl. really tough most problems are at slave cyl.
c hess
10-18-2006 17:41:27
If your tractor has manual brakes have some one push on brakes -other person look at brake in question an if arm works with little cylinder on it your self adjuster may not be keeping brakes adjusted. As these tractors have some age on them adjuster may be rusted to rod going into brake.You can soak in wd40 an manually turn groved nut on rod. I believe power brakes also use same bottom parts .
John460
10-18-2006 10:38:48
I thought all Case 970"s had power brakes. This may be a dumb question, but how do you tell which brake system our 970 has?
DKase
10-18-2006 06:24:23
If you have manual brakes the problem is in the master cylinder. If you have power brakes the problem is in the hydraulic valve that is hooked to the brake pedal. DK
Tom (Ks)
10-19-2006 16:34:42
 Re: Case 970 brakes in reply to DKase, 10-18-2006 06:24:23
Darrel, is there is a plastic part that connects the petal to the spool? I do not remember what the brake act's like when it breaks apart. Have you ever had one break?
