SC CASE Oil Pressure
Glenn FitzGeral
10-17-2006 10:05:07
I'd like to see a little more oil pressure out of my '54 SC. Last spring I put in new rings and rod bearings. The cylinders and crankshaft(for the rods) mic'ed out nearly perfect. I replaced the rod bearings "just because". I never looked at the main bearings. Which would you say is the more likely culprit for slightly low oil pressure...main bearings or cam bearings?
Thanks, Glenn F.
B DeVol
10-22-2006 19:35:41
 Re: SC CASE Oil Pressure in reply to Glenn FitzGerald, 10-17-2006 10:05:07
Check the relief valve in your oil pump it may be stuck. I had the same trouble with an SO. Case had the spring available a couple years ago.
C. Amick
10-18-2006 09:32:28
I didn't think SC's had cam bearings? Perhaps the later ones did? You should be getting between 20 and 30 psi of oil pressure.
1stout
10-18-2006 13:00:27
 Re: SC CASE Oil Pressure in reply to C. Amick, 10-18-2006 09:32:28
In my opinion 30 psi seems a bit high to me. I have been wrong many times before though so I would appreciate some clarification on this. I also work on/use a VAC, do these have the same/similiar engines? Any help clearing up my confusion would be appreciated. Thank You.
Michael
C. Amick
10-20-2006 09:14:07
 Re: SC CASE Oil Pressure in reply to 1stout, 10-18-2006 13:00:27
The VAC carries 15 to 20 psi oil pressure. I don't know why the SC carries more oil pressure, but they do. I think they even had different graduations on their pressure gauges for this reason.
1stout
10-17-2006 18:04:09
What kind of pressure are you running. I rebuilt a VAC last winter and rebuilt the oil pump for it. It has good pressure now, around 15 psi. You don't need much when you don't turn many rpm. Good Luck
Michael
Camboted
10-17-2006 12:53:04
Glenn, my guess is the rods. Cam turns 1/2 as fast and should last longer, but have you checked the oil pump?? I'm told there is an adustment that can be made with a spring, but never looked into it.
