pto
comfortking
10-17-2006 05:10:13
Can I put a pto from a donor round nose 300 in a 310 with a shuttle drive? Thanks
Camboted
10-17-2006 17:20:53
 Re: pto in reply to comfortking, 10-17-2006 05:10:13
I hate to see good questions without any help. You need to find someone with the parts books. The 300RN had a PTO that worked as continous through the operation of the hand clutch in the torque tube. The 310, I believe had a true contious pto that drove off the main clutch disc. That means the 300RN got its power past the main clutch but off of the shaft before the hand clutch. Your shuttle goes in roughly the same location as the hand clutch. You'd have to see if there is clearance and if you can install the driving pinion on the main drive shaft. It couldbe that the shuttle uses this spot?? Sorry but I really don't know as I don't have the books.
