VA case needs help
John40
10-15-2006 06:49:26
have a VA series tractor. It has been making squeeling noises in the rear end and locking up on me . When I push the clutch peddle in the noise stops. When I let the clutch peddle out in neutral or in gear the squeeling starts and locks the tractor up like the brakes are on and kills the enjine. Sometimes when the engine is cold the tractor will drive like normal and after a few minutes it will start making noise in the rear end and lock up again. Does anyone know what coul dbe causing this problem and is it an easy fix, or do I have to start tearing the thing apart? Any help would be appreciated.
jhn40
10-17-2006 19:57:50
 Re: VA case needs help in reply to John40, 10-15-2006 06:49:26
Thanks for the help. I will do some more checking.
mj
10-16-2006 17:03:33
Check it out; click the link & click to enlarge a page.
Camboted
10-15-2006 17:10:38
It sounds to me like you have a bad bearing in the transmission. It gets warm, expands, and locks up. It is not in the brakes as it is doing this in neutral. The good news is that VA's are not hard to work on, and there are plenty of bearings and parts around. Get an IT manual and tear her down. LOL!
varmint
10-16-2006 17:06:07
 Re: VA case needs help in reply to Camboted, 10-15-2006 17:10:38
lol for what? man, you are to easy to laugh!
rgorange
10-17-2006 16:27:04
 Re: VA case needs help in reply to varmint, 10-16-2006 17:06:07
In this case I think LOL means Lots Of Luck instead of Laughing Out Loud.
