For Brian in Ohio LE, LAE, DE Belt Pulley--
LL.Lamp
10-12-2006 21:40:17
I am still looking for a belt pulley for my DE engine unit. What dia. does your LE have and what do you want for the pulley?
Brian in Ohio
10-13-2006 05:05:06
 Re: For Brian in Ohio LE, LAE, DE Belt Pulley-- in reply to LL.Lamp, 10-12-2006 21:40:17
Mine's an LAE, and I'll have to check for you and report back. Don't know if the pulleys are interchangable between the LAE and DE or not.
L.Lamp
10-13-2006 19:27:11
 Re: For Brian in Ohio LE, LAE, DE Belt Pulley-- in reply to Brian in Ohio, 10-13-2006 05:05:06
Thanks for checking. I have a parts book for an LAE and DE and they indicate they take the same pulleys. Measure your LAE output shaft the pulley fits on and let me know what you find out. Thanks!!
Brian in Ohio
10-14-2006 04:35:32
 Re: For Brian in Ohio LE, LAE, DE Belt Pulley-- in reply to L.Lamp, 10-13-2006 19:27:11
I haven't made it to the shed to measure that for you yet, but if this makes a difference to you, the belt pulley is not a flat pulley. It's set up to run a bunch of V-Belts. Will this work for you?
L.Lamp
10-16-2006 22:15:36
 Re: For Brian in Ohio LE, LAE, DE Belt Pulley-- in reply to Brian in Ohio, 10-14-2006 04:35:32
Brian, I am looking for a flat pulley. Thanks for the info.!!
