LA Case magneto
Jason Bryan
10-11-2006 15:24:32
Another question for you Flambeau experts: Who tunes up Case mags. The mag on my LA is real sensitive and you have to hold your breath when you touch the spark advance while starting. I have a bunch of NOS points and things that fit Case mags. Also when under a load it will sometimes start backfiring and adjusting the spark advance will not change it. Any suggestions?
Walt Davies
10-12-2006 11:41:20
 Re: LA Case magneto in reply to Jason Bryan, 10-11-2006 15:24:32
Jason I found this on Ebay its just what you are asking for and he says it is tested and gives good blue spark on all for leads.
Walt
Link
Jason Bryan
10-12-2006 19:15:39
 Re: LA Case magneto in reply to Walt Davies, 10-12-2006 11:41:20
Thanks Walt and Camboted, I'll try the condensor first and see what happens.
Camboted
10-11-2006 23:16:26
Where are you located? There is an 'old guy' (nick name is "Two thumbs") in Rockford, IL area (been rebuilding mags for 55 years), but he isn't cheap! Personally, I'd bet you need a new condenser. You can use a one wire condenser if you have the base grounded. If you can take it apart without loosing the timing, change the condenser, polish the points, set them about .015", give it a good cleaning and see what happens. LOL! If that dosn't work go see:
Dennis Branson, 7722 Elm Ave., Loves Park, IL 815-633-4262
Walt Davies
10-11-2006 16:31:33
sounds like you need to go though your mag here is a website that has the manual to help you.
Link
Good Luck
Walt
Jason Bryan
10-11-2006 20:06:17
 Re: LA Case magneto in reply to Walt Davies, 10-11-2006 16:31:33
Walt, That material on that site looks awfully scary to me. Do you know of anybody that works on them? Jason
