CASE VAC, 1949 - 1952,
Robert Price
10-10-2006 18:56:26
Need some help. Having a Case VAC 1949 - 1952, VT328 Block, engine rebuilt, top to bottom. Need Front Engine Cover with Governor Rod being operable. Its been a project, but I hanging tough. I want to see this baby Run. Can anyone help with request, or send me to the dealer man.
Robert Price
1031D
10-11-2006 18:53:49
 Re: CASE VAC, 1949 - 1952, in reply to Robert Price, 10-10-2006 18:56:26
I have a front cover laying on the floor of my shop with the governor rod/flipper and governor to carb rod also. If my memory serves me right, the roller bearing in it is tight. What is it worth to you?
BarryfromIA
10-11-2006 17:00:29
Do you have a parts book for that model engine? I had my 210b apart about 5 years ago and fixed the rod. The govenor lever is held on with a rollpin, then the shaft and needle bearing can be pushed or driven out the top. You will then need a small bearing puller to remove the bearing. If you are carefull you can clean it up and find a bearing number. It was common bearing but not a stock item.
amo
10-10-2006 20:12:24
try web site vintagetractors.com, good to deal with. good luck
