Case 1494 Hydrashift problems.
Marty G.
10-10-2006 11:44:16
Hi all. I am the new owner of a 1494. It's 2 WD with Cab. Real clean. I was wondering if there is any adjustments on the transmission to be performed or if they malfunction it means overhaul? The symptoms are as follow, nothing happens in 1-2 ranges, speeds up in 3rd range and fall back to lower speed in 4th range. Any insights from anyone will be appreciated.
Mitch Furness
11-04-2006 19:46:09
 Re: Case 1494 Hydrashift problems. in reply to Marty G., 10-10-2006 11:44:16
Marty you need a manual for these machines. The hydro box's can be difficult. Should get one at manuals.us Good tractor appart from box.
There is also a David Brown forum on>Link
as>Link these machines are actually David Browns made in Brtian. This forum is really good for these machines.
Regards
Mitch
