dc timing
johndeereman
10-10-2006 10:53:13
how do you set the timing on a dc is it similar to a jd b where you put #1 cylinder on top dead center compresion stroke then turn the mag until it clicks.tractor overheats going down the road in high gear took radiator off and flushed everything real good got good circulation when take cap off so dont think its plugged but might be out of time just a little.
joe bu
10-10-2006 19:24:42
 Re: dc timing in reply to johndeereman, 10-10-2006 10:53:13
That should be close. The way I check it is to have the engine running. Put the tractor in third gear, engage clutch and stand on both brakes. If the govenor kicks in and it keeps running, the timing is good. If it kills the motor, you need to make a slight adjustment. This works for me.
