LA Tread width
Jary
10-10-2006 04:40:40
Can anyone help me with the distance from outside to outside of the rear tires on an LA? I purchased one recently and I would like to make sure my trailor is wide enough!
Walt Davies
10-10-2006 08:55:28
 Re: LA Tread width in reply to Jary, 10-10-2006 04:40:40
I two LAs with both size tires. The 14X30 is 76 inches and the 15X30 is 79 inches.
You had better have a heavy duty trailer as the weight can be as high as 9,000 lbs with water in tires nad full of gas and oil and water in tractor. Also does it have the wheel weights they can add anothe 4 to 500 lbs.
My 1945 LA with water in tires and no wheel weights but with 350 lbs driver and full gas tank weighed in at 8.975 lbs.
Walt
