Interested in a VAC
lark 4-dr
10-09-2006 19:20:45
I stumbled across this form on the innternet and thought i'd ask for an opinion of the readers.
I'm looking at a 1948 VAC that is for sale locally (SW Michigan). It seems to be in pretty good shape mechanically, even tho' it'd been used regularly in a local bluberry farm for the past 40 years.
Engine seemed tight, no bearing noise. Transmision was noisy, but this didn't seem from wear. it has a pto and a woods 42inch under-slung mower, which seems quite sharp. it's manually raised. The outer axle bearings were redone as well as the disc brakes. it has no headlights any longer and no hydraulilcs. I've been looking for a 'deal' to mow my 3 acres. At $1500, this set-up is almost right for me. The mower is a bit small, and the tricycle set up a bit unnerving to me, but it seems like one that will run for another 50 years without much maintenance. Tires are ok, no cracks, good tread. The paint is red, but it ain't originaly and there isn't any trace of decals left on the thing. Anyone have any thoughts? Thanks!
