Oil leak
Denny ia
10-09-2006 14:46:26
I have a 47 Case SC. Went for a tractor drive Saturday (20 miles) I noticed oil leaking from around where the starter is mounted and also by the govner. What could be causing this? Thanking you for your assistance. Denny H
Walt Davies
10-09-2006 15:24:25
 Re: Oil leak in reply to Denny ia, 10-09-2006 14:46:26
The starter should have 1/4 in. thick cork gasket around the mount. The Governor most likely needs to be removed and new gaskets and seals installed.
seals are available at any bearing and seal store and the cork gasket can be made from material bought at any auto parts store.
Walt
