DC tires?
Nick in Kansas
10-09-2006 06:40:42
Has anyone ever tried using 18.4-38 tires on a DC? I bought a 14ft Krause disc this weekend, and don"t have enough tire to pull it. The old gal acts like she has plenty of power just short on traction.
BarryfromIA
10-10-2006 18:04:26
 Re: DC tires? in reply to Nick in Kansas, 10-09-2006 06:40:42
Do you have 3 sets of wheel weights on the tractor now? Dads DC3 always had three sets. It always pulled a 14 foot Case disc in corn stalks. Later on a 730 replaced it, and after that a 1030 got the job of pulling the same disc. The dc became the feed wagon tractor, it could out pull the 1030 in mud.
Glenn FitzGerald
10-10-2006 05:02:52
I like big tires as well. (I have 15.5's on mine with 14" rims.) I don't know what tires you have now but a good set of 13.6x38's with 80% fluid will pull unbelievably. We have always kept Dad's '51 DC(bought new) in good 13.6s and for it's size it is the best pulling tractor on the farm. A 10' disk is PLENTY for a DC, especially in spring plowing.
Glenn F.
DKase
10-09-2006 19:21:26
I have 20.8 X 38's on 2 of mine. It is amazing what they will pull, especially in mud. A lot of the additional traction is due to the higher drawbar. If you go to Tractor Photos and search for (Case DC DKase) you will find a picture of one of them. Kinda a dark picture, but you will get an idea of what it looks like. DK
dej(JED)
10-09-2006 07:49:46
I have run 18.4 x 38's on a Farmall M. This is about the same power tractor I would think. The case Dc might be a little stonger. I was pulling a 10 foot disk with a 12 foot springtooth behind it. The wider tire helps, but you really need weight. The first time over on sod was murder.
I spun at every rise and fall. Adding about 300 lbs per side helped a lot.
Josh in Pa
10-09-2006 06:45:58
I think your gonna be short on tractor all the way around, but maybe you could try duals? That way if it didn't work out you wouldn't be stuck with the bigger tires and rims. Josh
