LA Case cylinder head casting number
Rachel Bryan
10-08-2006 20:01:05
I have an LA head with the number 5845A cast into the spark plug side of the head. On the top of the head, under the valve cover the number 5117 is cast. Can anyone tell me what application this head is for?
Jason Bryanr
10-09-2006 21:03:07
 Re: LA Case cylinder head casting number in reply to Rachel Bryan, 10-08-2006 20:01:05
Walt, I have an LA with a junk head and my plan is to put this high-comp head on it. Thanks again for the info! I'll have more questions in the future for you guys. Jason
Walt Davies
10-10-2006 08:42:59
 Re: LA Case cylinder head casting number in reply to Jason Bryanr, 10-09-2006 21:03:07
Jason.
Does your head have round or oblong depressions in it. The oblong ones are for the LP engine and has the highest compression 8 to 1. Also does your pistons come above the block at TDC, these would be high compression pistons. I have a set oF them that are up for sale if you are interested.
Walt
Will T
11-02-2006 17:16:52
 Re: LA Case cylinder head casting number in reply to Walt Davies, 10-10-2006 08:42:59
walt do you still have the hi compression pistons for sale and are they new or used? If used what kind of shape are they in and what do you want for them? THANKs WILL
Jason Bryan
10-10-2006 16:11:17
Walt,If your talking about the combustion chamber portion of the head, then mine has oblong depressions. I don't know what kind of pistons I have yet. How much for yours? Who works on Case magnetos? I have several NOS parts for these mags but don't really know if I've got the mag tuned the way it needs to be. Thanks, Jason
Don Livingston
10-09-2006 05:03:36
You have a high compression gasoline head. Don L.
Jason Bryan
10-09-2006 13:17:02
 Re: LA Case cylinder head casting number in reply to Don Livingston, 10-09-2006 05:03:36
I don't know how my wife's name got on there but the info was actually for me. I thank you for the info. Any idea of its'worth? I found it laying outside a man's barn with anti-sieze smeared all over it and it had new valves and seats installed. Thanks, Jason
Walt Davies
10-09-2006 15:18:50
 Re: LA Case cylinder head casting number in reply to Jason Bryan, 10-09-2006 13:17:02
If it has no cracks in it then its worth around $200 to $250 if it has cracks then it worth anything from junk price to around $100
have magnefluxed to see it its Ok then put it on Ebay under Tractor case LA Head. Walt
PS If you want to sell it to me then its not worth anything but I will pay for the shipping giggle.
