LA Case rear hydraulic drum brakes
Jason Bryan
10-07-2006 20:25:17
I would like to correspond with anyone having knowledge of part numbers or replacent master and wheel cylinders for these brakes.
Walt Davies
10-07-2006 20:38:12
 Re: LA Case rear hydraulic drum brakes in reply to Jason Bryan, 10-07-2006 20:25:17
Take them into any good auto parts store like Napa and they should be able to match you up with a rebuild kit.
I have some used parts on my parts tractor if you need anything. Walt
Jason Bryan
10-07-2006 21:14:41
 Re: LA Case rear hydraulic drum brakes in reply to Walt Davies, 10-07-2006 20:38:12
Thanks for the tip. Do you have any info on LA cylinder head part numbers and their fuel requirents(kerosene,gas, or LP?) Thankyou, Jason
Walt Davies
10-08-2006 08:56:50
 Re: LA Case rear hydraulic drum brakes in reply to Jason Bryan, 10-07-2006 21:14:41
3943AA---Gasoline and low cost fuels.
3947AA--- Gasoline and low cost fuel when used with high altitude pistons A4451A pistons
4767AA Lp head
walt
Jason Bryan
10-08-2006 13:17:08
 Re: LA Case rear hydraulic drum brakes in reply to Walt Davies, 10-08-2006 08:56:50
Thank You! Sincerely, Jason Bryan
Walt Davies
10-08-2006 08:59:28
a good source for manuals on the LA is ebay.com
Just enter Case LA for your search and you should find both the Service manual and Parts manual also the little operators manual.
Walt
