La with Plow
Mark in Iowa
10-07-2006 18:16:36
Hi, My club is having a plowing day, some bean stocks and some in disk corn stocks. I have a Case La 1948..with no hyd. I have a 4 bottom trip 16 plow w/colters and a 3 bottom trip 14 w/colters... Since I never done this with this tractor ..was wondering which plow I should use and what gear should I be in.[ don't want to look any stupider than I am ] What I been reading this is a 4 or 5 bottom tractor....I know land is different in different parts of the country...I'm in Iowa...the middle of it.. I want to THANK any and ALL ADVICE I get in advance....I read this site ever nite and get a lot of advice from other people questions.. THANKS....Mark
Steve Davies
10-08-2006 14:44:13
 Re: La with Plow in reply to Mark in Iowa, 10-07-2006 18:16:36
Have been to a ploughing competition to day in England (UK) with my `44 Case SC the only Case out of 90 people taking part.Also the only tractor with 3 wheels. I use a 2 furrow plough 10 inch spacing.Hand clutch and 3 wheels make driving straight difficult.
Mark in Iowa
10-08-2006 07:42:14
THANKS so much for EVERONES information.....I forgot to say ...we are plowing in river bottom.. it's south east of DesMoines..
THANKS again....Mark
Jerald Wyssman
10-08-2006 07:28:31
I'm looking forward to here how your LA preformed. I have a '49 LA w/hyd. and a 4-14 plow. You've received some good advice here. I too would start with the 3-14. I have trouble with the break-away hitch if the ground is real tight. These old LA's will work though.
Roger H
10-08-2006 06:00:07
Where is it going to be & when?
Camboted
10-08-2006 00:37:52
I used to farm in this area and if you are north of Des Moines you are probably in the Clarion, Nicollet, Webster soil association. This is a silty-clay-loam and I used to pull 4-16's with an IH 560. Your LA should handle 4 bottoms if it is good shape. Make sure it dosn't overheat in a pull.
Walt Davies
10-07-2006 20:35:01
I have an LA that is pulling at around 80 draw bar HP I have pulled my 4 bottom but its not easy in this hard clay soil.
This summer with no rain I was down to my two bottom in hard clay. It was too hard even for the 3 bottom. If you can put a shovel in the ground with ease then use the 4 bottom 1st gear. These LA's are geared pretty high in 1st ans 2nd. You might want to start with the 3 bottom and work up just to be sure of the ground. She will pull a 5 bottom in soft ground but hard ground can give you fits. My 3 bottom has the trip hitch and it trips in hard clay so much that I can't use it. If your ground has been worked a lot then the 4 bottom should no trouble. show those Ugly green things what real pulling power is all about and let us know how you did.
Hope this helps Walt
Don Rudolph
10-07-2006 20:28:43
You will probably have trouble plugging up on the disked corn stalks with the 14 inch plow-just not enough clearance for the amount of trash. Even a 16 will plug up in corn stalks. If your LA is in good shape it should pull the 4-16's all right, just plow shallow (6 inches and in 1st gear to start with. In sod I would suggest the 3-14 plow. Good Luck!
scott6143
10-07-2006 18:47:07
Personally I would take the 3-14s and run in second gear, save the 4-16s for a day and feild when nobody is watching (lol) that way you can decide the gear and depth with no one to see if you mess up...
