580C Brake cyl rebuild ???
n8xv
10-06-2006 16:05:41
Stepped on my right side brake and it went right to the floor. Remove the floor pan and removed the cylinder which was leaking. The O ring is badly worn and the piston shows wear on one side. I want to rebuild both right and left as long as I have the floor pan out. The cylinders in both look very pitted, not sure a hone will clean them up. Does anyone know of a source for replacing them if the cylinders cannot be saved?? Also does a new piston come in a rebuild kit?? The cylinders are Bendix and looks like the number is 222G109.
Joe (Wa)
10-06-2006 20:29:52
 Re: 580C Brake cyl rebuild ??? in reply to n8xv, 10-06-2006 16:05:41
A source.
Joe
