case 350 engine parts?info?
Jerry Thenen
10-06-2006 15:34:56
does anyone know a good place to buy an engine rebuild kit for a case 350? Any good info to know before tearing into it would be great too.
Thanks,
Jerry Thenen
Don Livingston
10-09-2006 05:06:53
 Re: case 350 engine parts?info? in reply to Jerry Thenen, 10-06-2006 15:34:56
I stock the sleeve and pistons, Case built 164 ci gas.
Don L.
just Case
10-07-2006 18:15:34
I believe that the 350 has the 188 diesel. Follow the link to a source for a rebuild kit.
Dale Roisum
10-07-2006 07:28:13
I overhauled my 611B (same 164 cu. in. motor) two years ago. I bought the piston/sleeve sets from the case dealer. I even found a new old stock camshaft through the dealer search. Valves (stainless for unleaded) bearings and gasket set were ordered through my local machine shop (felpro gaskets, and Clevite bearings) The sleeves are dry sleeves so the bores should be honed for the new sleeves that way they will not distort them if just pressed in.
John Saeli
10-07-2006 10:21:32
 Re: case 350 engine parts?info? in reply to Dale Roisum, 10-07-2006 07:28:13
Hey Dale: Case seems to be the only supplier of engine parts for the 164 engine. But, the last I checked, they didn't have assemblies, everything had to be ordered separately, which made it expensive. Was it a NOS set?
