Case 580CK Steering fluid
Kelly R
10-06-2006 12:40:30
I borrowed an old (1966-71?) diesel 580 CK from a coworker in order to do some excavating on our property. Runs like a top, but leaks a little hydraulic fluid. Anyway.... steering has started to become quite difficult. I assume being that its a hydraulic steering setup that I can use the same hydraulic fluid for the power steering as well? And for that particular model, the steering system fill cap is the one on the right side of the engine, near the front? This is one aspect I never went over with the owner, and he's presently out of the country on holidays. I realllly don't want to mess up his baby by putting the wrong fluid in the wrong hole :P
just 580's
10-07-2006 18:20:48
 Re: Case 580CK Steering fluid in reply to Kelly R, 10-06-2006 12:40:30
You�re right. You can use the same hydraulic fluid that is used in the Hydraulic system and the torque converter in the steering.
Kelly R
10-10-2006 12:03:48
 Re: Case 580CK Steering fluid in reply to just 580's, 10-07-2006 18:20:48
Thanks very much for the reply. Cheers!
