LE Power Unit ?
Bobl1968
10-06-2006 06:56:23
Would anyone happen to have a pic of a LE power unit that might show the gas tank? I have the power unit, and the tank that came with it if off of a L tractor. It is shaped like the hood on the engine, but looks too long just sitting on the mounts. I guess my question would be would the tank on the L tractor be the same as the LE power unit? I believe the Power Unit to be a 1939, as the first two digits in the serial # are 43. Thanks for any help or advise. Bob
Brian in Ohio
10-06-2006 08:41:18
 Re: LE Power Unit ? in reply to Bobl1968, 10-06-2006 06:56:23
I don"t know if they are mounted the same way, but I have a LAE Power Unit that I"m parting out, If you need a part or two, let me know and maybe we can strike a deal.
Brian in Ohio
10-06-2006 08:41:17
Chances R
10-06-2006 07:03:28
third party image
The bottom is a LE the top is a CE.
Klyde
10-06-2006 21:29:20
 Re: LE Power Unit ? in reply to Chances R, 10-06-2006 07:03:28
I thought I was the only one with that screwed up paper!! the top one is an LE the bottom is a CE.. Look at the hand hole covers.
Bobl1958
10-06-2006 07:20:50
Thanks a lot for the picture. It's a big help.
charley hellickson
10-07-2006 22:16:44
 Re: LE Power Unit ? in reply to Bobl1958, 10-06-2006 07:20:50
Hi Bob. No one has caught it yet or said anything. You might be figuring the serial number wrong. On the L and C you take the first and fourth number and subtract three. On the D & LA you take the first two numbers and subtract four. If your engine is like the one in the picture it is an L. Thanks. Charley.
Chances R
10-08-2006 06:10:23
 Re: LE Power Unit ? in reply to charley hellickson, 10-07-2006 22:16:44
When the serial number has seven digits, you are supposed to take the first two digits and subtract four. When the serial number has 6 digets you are supposed to take the first and fourth diget and subtract three. As far as labeling them CE and LE I just told you what was on the literature. I guess Case may have screwed up :)
L.C.Gray
10-08-2006 07:11:35
 Re: LE Power Unit ? in reply to Chances R, 10-08-2006 06:10:23
Don't forget the exception to seven digit rule.....
7 digits begining less than 42 use the six digit rule. Should only come into play on '36 and '37 models. Their production exceeded the six digit capacity those two years prompting them to change their serialization system for the '38 model year.
charley hellickson
10-08-2006 21:32:45
 Re: LE Power Unit ? in reply to L.C.Gray, 10-08-2006 07:11:35
Hi L.C.Gray. Thank you for explaining that. I thought all L & C serial numbers were figured the same. I didn't know that Case changed the numbering befor the LA & D came out. I learned something new and important. I have 1929 L, my Dads favorite tractor. He used to tell stories about one. One day I had to have one, so I went to an auction and bought one. Good luck. Charley, L C H.
