CASE 930 FUEL INJECTORS
JOHN, MCGEE
10-05-2006 16:44:11
HOW DO I PRIME THE FUEL INJECTORS ON A CASE 930 TRACTOR.
Eric John
10-05-2006 20:36:20
 Re: CASE 930 FUEL INJECTORS in reply to JOHN, MCGEE, 10-05-2006 16:44:11
If you are meaning bleeding fuel system, after filters are bled losen infector line at injector, turn over motor until fuel pumps out. If necessary you may have to do all. One or two will usually get the tractor to start up.
Bill in oh
10-05-2006 18:33:38
Well you got me to thinking prime injectors on 930 engine ?. not sure if you are wanting to prime injectors or the fuel sym.need more information as far as injectors there is no priming.
JGarner
10-06-2006 05:49:27
 Re: CASE 930 FUEL INJECTORS in reply to Bill in oh, 10-05-2006 18:33:38
Priming not needed, but I think what he is asking is about bleeding and that does need to be done to remove air trapped in the system that can restrict fuel flow TO the injectors.
