forgot to mention....
Joe-Bob/IN
09-14-2006 12:38:30
Forgot to say that it will go in almost normal if the tractor is just rolling backward. And if on flat concrete when you do get it into gear it just starts to move backward and acts like it has some pressure to go backwards but will release when you take it out of gear, all while the inching pedal is depressed.
c hess
09-14-2006 16:29:27
 Re: forgot to mention.... in reply to Joe-Bob/IN, 09-14-2006 12:38:30
Try to idle when you shift an when you push in clutch an hear engine labor -that is time to rapidly put in gear as as powershift is changing from forward to reverse.AS for shift slipping when shifting to 3rd powershift your torque linmiter on flywheel might be beginning to slip.
John Saeli
09-14-2006 18:16:23
 Re: forgot to mention.... in reply to c hess, 09-14-2006 16:29:27
Our experience is that to get the gears to stop grinding is to rev the engine up some.
