Case o matic fluid change
Jacob Meuth
09-12-2006 14:33:26
I have just restored an 811 case and in the process we found that the engine air breathers were clogged and have blown about 4 gallons or motor oil into the torque converter housing over the years. One how bad is this and two we want to change the oil i have read on here that hy trans is a good choice. Is it a ten wieght oil like the manual calls for? Has anyone had problems after changing the trans fluid. I know that it has not been changed on over 25 years. Could this cause a problem. Thanks Jake
JW
09-12-2006 17:20:09
 Re: Case o matic fluid change in reply to Jacob Meuth, 09-12-2006 14:33:26
Don"t use Hy-Tran, use Case TCH oil. It is avalible at any good Case IH dealer. Its a thinner oil and seems to work better in all our c-o-ms that we use for regular work
Lincoln
09-12-2006 17:15:23
I have always used hy-trans in my 611B. What ever brand Tractor Supply happens to have. The 611B has two drain plugs in the torque tube, as well a drain plug in the torque converter. The one in the torque converter is found by looking up into the rear drain plug. Mine has two filters as well. Not sure if your 811B will be the same.
old
09-12-2006 14:53:52
I changed and cleaned the filter/oil in my 800B and didn't have any problems. I even called the case dealer to see what type oil to put in and they told me any good hyd fluid or transdrolic fluid would work well.
