Case 830 brake problem
Rich coursen
09-11-2006 21:06:02
Need some advice. Have an early model 830. I use it on my ranch. when I press the left brake pedal down. It locks the left wheel. I then have to go in reverse to unlock the brake. has somebody had this problem before and if so, how do I get to the brake assy to fix it?
Thanks for the help,
Rich.
Gene Dotson
09-12-2006 06:03:16
 Re: Case 830 brake problem in reply to Rich coursen, 09-11-2006 21:06:02
Rich;
I had the same problem with my 700. The problem was broken retract springs between the discs. There are 3 of them that go between tabs on the brake discs that return the discs to neutral position. These springs are still available from CaseIH... Gene
Graham from NZ
09-12-2006 01:25:43
Probably need to take the brake to pieces and clean all the dry dust etc out of the whole assembly (including the actuating balls)and the splines, and re-asemble.
Rich Coursen
09-12-2006 14:39:34
 Re: Case 830 brake problem in reply to Graham from NZ, 09-12-2006 01:25:43
Thanks for the reply. I am willing to bet you are right about my brakes. I have a manual (I&T) not too fond of it. Have not dug it out since I am out of town. Do you Know how I am going to get to the brake assy? through the top or do I need to go through the sides (axle housings)? have never dug in there before.
Thanks,
Rich.
CK RICHARD
09-12-2006 15:57:49
 Re: Case 830 brake problem in reply to Rich Coursen, 09-12-2006 14:39:34
Rich just take off the brake cover . brakes are not on the axles
Rich Coursen
09-12-2006 20:18:54
 Re: Case 830 brake problem in reply to CK RICHARD, 09-12-2006 15:57:49
CKrichard, will take off brake housing and do what I need to do. thanks for the help.
Rich.
