Rim repair
JGarner
09-11-2006 14:51:07
One of my 36" spin out rims has a hole rusted through. It is small and the liner or earlier repair seems to hold the tube in but looks bad cosmetically. I need advise on how to repair it or a place close to Houston, TX that may have replacement rims.
I haven't had the tire off yet, so I don't know what the rest of the rim's inside surface looks like so I don't know if its worth repairing yet.
Anybody ever cut the spin out rails off one and weld them on a new rim? Any pointers?
petetx
09-11-2006 20:23:42
 Re: Rim repair in reply to JGarner, 09-11-2006 14:51:07
Try Eagle Tractor In eagle Lake 1-800-833-5867
JGarner
09-13-2006 14:28:17
 Re: Rim repair in reply to petetx, 09-11-2006 20:23:42
Eagle Tractor doesn't seem to have much time for the restoration crowd. This salvage yard will be very low on my contact list. The old guy I talked with was very short with me when he found he didn't have anything that would fit and was not going to make an immediate sale.
DKase
09-11-2006 18:07:44
WD 45's are very well known for rotted out rims. On mine I found a third rim that was bad around the stem also. I cut good pieces out of the third rim by cutting right next to the spin out rails and welding onto the rails of the other rims. Drill a new hole for the stem, and you will be off and running. I did that ten years ago and it is still running. Make sure when you weld back togather that the rim is not larger diameter than it was to start with, or it might not lock on the rails properly. Good Luck DK
