Case SC starter
Gobind
09-11-2006 05:30:43
I was trying to start my '54 Case SC in the rain the other day and either had too much or too little choke and it didn't want to go. I had the starter cranking for 2-3 minutes and was starting to get a pop or two out of the engine when all of a sudden the starter just stopped responding to the starter button. The battery's still got plenty of juice. I'm thinking I either burned out something or the starter got stuck in the flywheel. A friend with experience with tractors suggested towing it with my other tractor to get it started and verify that everything works. I'm wondering if anything (like the flywheel or the starter) might get damaged in the attempt. I'd appreciate any advice.
Nedd
09-11-2006 08:51:28
 Re: Case SC starter in reply to Gobind, 09-11-2006 05:30:43
I would guess after 2-3 minutes of cranking the cables got a little warm. I would check all the cables and starter switch/solenoid. Was the starter humming or making any noise when you tried it again? I'm leaning toward electrical, but listen to Walt on the mechanical.
Walt Davies
09-11-2006 07:59:59
If the starter is stuck then don't tow it or you damage the engine or something in the drive train. To unstick the starter just loosen the bolts and rock it a bit it will pop right out.
Walt
Gobind
09-11-2006 10:34:38
 Re: Case SC starter in reply to Walt Davies, 09-11-2006 07:59:59
No humming that I noticed. I'll try loosening the starter. Thanks.
