What starters will fit an early LA?
Canuck_case
09-10-2006 19:25:37
Looks like the old one is toast. I've tried to get it turning but the brush holders are weak and bend. (as well as other issues). Does anyone know if other starters can be used on the LA, and if so which ones.
Thanks,
Kelly
1200TK
09-11-2006 15:02:30
 Re: What starters will fit an early LA? in reply to Canuck_case, 09-10-2006 19:25:37
Hello Canuck case,
I note your asking if any other starter will fit an early production "LA", yes, surprise surprise, but the starter motor from a "D" Series tractor will go straight into place and do a very good job of starting your "LA".
My brother put one into his "LA" and it works just fine, you would not know the difference, and also it does not look out of place.
Hope that this helps.
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
JGarner
09-11-2006 14:36:00
I would find al ltrenator/starter rebuild shop and have it put back in new condition. It will cost you less and you will know what you have then as they will rewind or check windings and replace brushes, bushings, bearings etc.
