Case 300 electrical
hobbyfarmerinwi
09-10-2006 19:08:23
I hope I can explain this.
1957 Case 311 6 volt tractor. When I charge the battery, it will hold a charge for a very long time, and when I start it for the first time after charging, the battery will spin the motor as well as anyone could hope.
After I turn it off, and go to re-start it, the battery seems to only have enough to hardly turn it over at all. This happens if I re-start it 1 min or 1 week after running the tractor.
The loss of battery power does not get worse, or better, if the tractor runs 3 mins or 3 hours.
What is causing the constant "low charged" battery?
C. Amick
09-11-2006 09:20:09
 Re: Case 300 electrical in reply to hobbyfarmerinwi, 09-10-2006 19:08:23
How many charging amps does the ammeter show when the tractor is running? Does the ammeter needle got to zero with the tractor off?
hobbyfarmerinwi
09-11-2006 17:39:17
 Re: Case 300 electrical in reply to C. Amick, 09-11-2006 09:20:09
Yes, it does go to zero when off
C. Amick
09-12-2006 09:50:56
 Re: Case 300 electrical in reply to hobbyfarmerinwi, 09-11-2006 17:39:17
It doesn't show a discharge when off, right? Has the tractor been this way since you have had it? You should have at least Size No. 2 battery cables for 6 volt. Size No. 1 is even better. I have no more ideas right now.
