VAC transmission gasket
case
09-10-2006 17:13:04
I am in need of the gaskets to go between the torque tube/transmission and transmission/rear axle. Can anyone give me some info on where these can be bought. Thanks for the help, Case.
Joe (Wa)
09-10-2006 20:42:31
 Re: VAC transmission gasket in reply to case, 09-10-2006 17:13:04
Buy some bulk gasket material. Hold the gasket material up against the flange, with a ball-peen knock out several of the bolt holes.
Use bolt/nuts with flat washers to hold the gasket securely against the flange, knock out the rest of the holes.
Tap around the border of the flange inside and out, you don't have to cut clean through the gasket with the hammer, just make a good continuous impression of the outline and then finish the cut with scissors.
Joe
Watsonsgotit
09-10-2006 18:25:59
The gasket in question is still available from your Case IH dealer.
