51 DC Hand Clutch lever
IA Roy
09-09-2006 22:18:29
I was looking at mine today and was wondering if mine is on backwards. The lever is very close to the battery shelf, and I have scraped knuckles on occasion when engaging. I wonder if it is supposed to offset in toward the steering shaft or out towards the wheel. It appears that it would go on either way, and there would be quite a difference in clearance.
Glenn F.
09-11-2006 09:34:25
 Re: 51 DC Hand Clutch lever in reply to IA Roy, 09-09-2006 22:18:29
Reversing it may solve the problem, but I think they are offset towards the steering shaft when new. When everything was new/tight, it cleared the battery stand OK.
Glenn F.
Dale L
09-10-2006 06:42:09
My 2 '51's are the same way. they've got a lot of play side to side. I thought it was caused by the bushing or bolt being worn. I'll have to go out and see if turning it arond will do the trick.
Jim Voyles
09-10-2006 03:08:28
I think all of my DC series have the lever set away from the battery box towards the wheel as you described. Unless you enjoy skinning your knucles (and you probably don't)switch it around.
