case magneto
Joe Wagner
09-09-2006 20:27:32
Im helping a friend with his SC case. There is no spark at all. When I looked at the magneto it appeared to have rust on the inside. So I took it apart and tried to clean it the best I could. There was a lot of rust on the inside. I put it back together but still no spark. I heard that once you pull them apart, you have to recharge the magnets, is that true, and can any one tell me what else to check on the magneto. He put in new points and a condensor already. Could it be that the gap in the magneto is to great now becasue of the rust problem?
Walt Davies
09-10-2006 08:22:58
 Re: case magneto in reply to Joe Wagner, 09-09-2006 20:27:32
Go to this site to see a manual on the case magnetos
Link
Walt
By the way how does removing the magnets educe their magnetism. I can't see anyway that would do any anything to them I have rebuilt a lot of old mags and never had any trouble removing the magnets. You need to get all the rust out of the system even inbetween where the small fins go together to hold the magnets in.
Joe Wagner
09-10-2006 18:26:13
 Re: case magneto in reply to Walt Davies, 09-10-2006 08:22:58
Walt
Thanks for the info on the manual. I had already been to that sight. This is the first mag that I have worked on. On page 25 of the manual it states that by removing the rotor out of the frame the rotor is weakened. I will have to print the manual out so I can read it better.
Thanks
Joe
CNESLER
09-10-2006 06:28:17
Joe,
I would check the coil with an ohm meter.
Do not remove the magnets because they will get weaker. What is the brand and model of mag?
Cleanig up the rust should not hurt anything.
Good Luck
CNESLER
Joe Wagner
09-10-2006 18:31:39
 Re: case magneto in reply to CNESLER, 09-10-2006 06:28:17
CNESLER
As far as I know it is a JMA magneto. Thanks
Joe
