case 801b
mike bonner
09-09-2006 14:28:20
I have found this tractor in complete condition. It has set for 8 yr. At this time it is not running but there asking $600 for it and 4 implements. Is that too much for this old case 801b and would this be a hard start for a new hobby?
mike bonner
09-09-2006 19:16:41
 Re: case 801b in reply to mike bonner, 09-09-2006 14:28:20
The tires are about 50% and one is low. The rear fenders have been repaired once but the rest is straight. I am going to try to turn it over. It comes w/brush hog, disk, plow, and scraper. There is very little fuel in the tank so there is some rust. I have pic's. I appreciate any info for I know not much about tractors. Thank you
old
09-09-2006 18:05:08
A lot depends on what comes with it, the rear tires and how good/bad they are. If its locked up or not and the sheet metal. $600 may not be to bad but on the other hand it might be to much also. Just depends on to many things to say for sure with out knowing more info on it
John Saeli
09-09-2006 17:51:54
Holy cow!! All that iron is worth that for scrap. Grab it.
scman
09-09-2006 15:08:41
Has the tractor been sitting outside or inside. Is the engine stuck? if so does it have antifreeze in the radiatior? what part of the country are you located in? What kinda shape is the sheet metal in? How are the rear tires? what are the four implements? all of these would affect the value..
sorry that my list was so long, but you have to be careful. this tractor could be completely shot not to mention it is case-o-matic which many people fear.
