Case DO
Russell Hunsing
09-07-2006 17:58:16
I recently purchased a 1951 Case DO. The tractor appeared to overheat the first time I ran it an extended time. It is full of water and does not appear to leak. Also, the radiator is clean. Any suggestions?
Don Rudolph
09-07-2006 20:56:55
 Re: Case DO in reply to Russell Hunsinger, 09-07-2006 17:58:16
Russell,
Unfortunately it could be a number of things. Here are some of them: thermostat is stuck, timing is off, head gasket is blown, head is cracked, radiator is plugged either internally or externally, water passages in engine are plugged. I have seen the water pump have to be smashed in order to get it out from the water jacket area that was completely plugged around all sleeves as well. Good Luck. Don
